Q-Jet ID please. - NCRS Discussion Boards
Q-Jet ID please.
  • Greg L.
    • March 1, 2006
    • 2291
    Q-Jet ID please.
    Could some of you Quadrajet experts help me figure out what this is for. I don't think the base plate is original but other than that I really have no idea what it could be for.
    There is a number "355" stamped in the aft, L/H corner of the base plate that might be a date code but that is it for stamped numbers. I'm guessing that it's 65-66 vintage but I'm no expert.
    Thanks.
    Greg Linton
  • Lyndon S.
    • April 30, 1988
    • 1027
    Re: Q-Jet ID please.
    It looks like a late 60s carter built Q-jet.
    • Greg L.
      • March 1, 2006
      • 2291
      That's what I thought on first glance but then I see noticed it used to have the part number stamped onto that disk(which is missing) so that led me to think that it was earlier.
      It also has a vacuum port above and to the right of the fuel inlet as well as some "funny" linkage where the choke rod comes up through the air horn...
      • Clem Z.
        • January 1, 2006
        • 9427
        what type of needle seat assy does it have as the very early ones has a special one. it is not like any type you have seen in any other carb.
        • Greg L.
          • March 1, 2006
          • 2291
          Ya you are right about that Clem. The only ones I have ever seen screw in but this one is held in place by a tab with two tiny screws. The primary rods piston is also held in place with a little clip. Others that I have seen just push down into the piston bore and are held in place with a plastic bushing.
          • Clem Z.
            • January 1, 2006
            • 9427
            the change happened in 67. old style carbs,7027200-201,7037200-201,7027202-203,7037202-203. new style carbs 7027210-211,7037210-211,7027212-213,7037212-213
            • Greg L.
              • March 1, 2006
              • 2291
              Thanks Clem, so basically this is a 7027200-201,7037200-201,7027202-203 or 7037202-203..correct? Could it possibly be older than 67 or is there something that you see that points to the numbers you referenced?
              • Clem Z.
                • January 1, 2006
                • 9427
                it could be older because the Qjet started on 396 chevys in 1965. during the 67 model year is when the needle/seat changed to the conventional type
                • Greg L.
                  • March 1, 2006
                  • 2291
                  Okay then..so it's before the change-over date in 67. Thanks a lot, that sure helps to narrow it down.
                  Do you know where I could find some more info on it to try and narrow it down even further. Did any 65-67 Corvettes use the Q-Jet? If not then it's obviously not even for a Corvette...
                  What do you think of the throttle plate....does it look correct for that carb? I thought that the threaded vacuum connection in the rear was a 70s thing but maybe not.
                  • Clem Z.
                    • January 1, 2006
                    • 9427
                    1966 chevy Q jet part # 7026202-210-203. check these # to see if they were used on a corvette. buick started using Q jets in 1966,caddy 1967,olds 1966 and pont 1966
                      Greg------
                      Although used on various Chevrolet models since 1965, the Q-Jet was not used on ANY Corvette until the 1968 model year. So, this carburetor was never originally used on a Corvette. However, it is generally similar in external configuration to those Q-Jets used on 68-72 Corvettes.
                      • Greg L.
                        • March 1, 2006
                        • 2291
                        So since there is no part number stamped on this carb do you guys think it would be possible to narrow down the application a little closer based on it's physical features?
                        Clem was very helpfull in determining that it is before the needle/seat change over in 67 and I don't think any other divisions used the 90 degree fuel inlet besides chevrolet so that puts it at a 65-mid 67 chev application or over the counter replacement.
                        Is there any other features that could be used to help narrow it down...maybe jet or rod sizes? Since this isn't a Corvette carb is there another site that you guys might know of that I could try for this info?
                        • Clem Z.
                          • January 1, 2006
                          • 9427
                          all the carbs use #71 jets. the 396/427 used #44 and #41 rods. the 327 used #45 and #43 rods
                          • Greg L.
                            • March 1, 2006
                            • 2291
                            How do you tell what size the rods are? If I remember right, other rods I have looked at have the size stamped on them but these have nothing on either one. The secondary rods hangar has a "K" stamped on it but that's it...
                            • Clem Z.
                              • January 1, 2006
                              • 9427
                              mic the diameters as the #s are in thousands of a inch. # 45 should mic .045
