Polalizing generator - NCRS Discussion Boards
  • Steve H.
    • November 1, 1996
    • 118
    Hello to all,
    I am in the final stages of reassembly on the '56 and will be starting it for the first time soon. I know that it is important to polarize the generator but my question is, if I use a battery cut off switch will I need to polarize the generator each time I re-energize the system or is it a one time deal?
    Steve
    Re: Polalizing generator
    Steve -
    I had battery disconnect switches on all my C1's, and never had to polarize unless I had the generator off the car and disassembled.
    • Steve H.
      • November 1, 1996
      • 118
      Re: Polarizing generator
      Thanks John.
      • Brett H.
        • January 1, 1996
        • 367
        In my experiences, once you polarize the unit, a battery disconnect switch will not affect it.
        Brett
          Technically....
          service guidelines teach mechanics to re-polarize a generator every time the battery is disconnected and re-connected. But, this is simply an exercise in good electrical due diligence.
          Once a generator has been properly polarized, it's pretty much good for the duration UNLESS it's been disconnected for a LONG time (years) and/or it's seen 'extremes' in temperature or shock/vibration during the disconnect period to disturb the prior polarization. That's why most will tell you it's no problem using a battery cut-off switch....
          • David Dawdy
            Re: C1 Generator,VR Polarization, etc..
            After installing a new wiring harness and voltage regulator, I connected my generator and gauge per the 1960 AIM, polarized and noticed that the 'BAT' gauge was reading positive as I cranked the engine. I thought that I had polarized improperly, so I checked and tried again and the result was unchanged. Puzzled, I later ask my good friend and guru who responded that there was a wiring error in the AIM indicating a reversal of the ammeter gauge wires. I have yet not tried reversing the wiring, is this true?
            • Jimmy B.
              • July 31, 1980
              • 584
              According to my "long lost" CHILTON's Repair & Tune Up Guide for 53 - 62 Corvette Copyright 1971 for POLARIZATION (note I personally wrote in the back of the book to myself): CROSS ARM & BAT on Volt Reg (make you a small wire) do this for a very brief period and you are now correctly polarized.
              I also found another handwritten note in the back of the book by yours truly. The steering arm (3rd arm) replacement bearing is a BOWER 5206-KS; perhaps Mr. Lucia wants to address this....
              Jimmy Blakely
              • Richard M.
                Super Moderator
                • August 31, 1988
                • 11302
                David, Yes the AIM is wrong. They have the RED and BLACK reversed in the diagram. Wire them the opposite and you'll be fine.
                Rich
                • David Dawdy
                  Thanks guys, It's done and things are back to normal.
