Correct WCFB carbs for 56 - NCRS Discussion Boards
  • Edward M.
    • November 1, 1985
    • 1916
    Can anyone tell me what WCFB carbs would be correct for an April 56 2x4 powerglide car? I am looking for the tag numbers, top plate numbers, body numbers, base numbers, and anything else?
    My ignorance on this subject is total.
    Re: Correct WCFB carbs for 56
    Ed -
    The info sheets from Gary Hodges show the '56 2x4 carbs are as follows:
    2362S Rear, 0-049 main body, 6-1114 (or 6-1122 early) air horn, 1-1387A throttle body.
    2419S Front, 0-049 main body, 6-1151 (or 6-1156 or 6-1203 late) air horn, 1-1387A (or 1-1387B late) throttle body.
    All 1956 2x4 carbs have idle air bypass screws in the side of the base.
    • Edward M.
      • November 1, 1985
      • 1916
      Thanks John, just what I needed. Now, what constitutes early vs. late for a 56? Would this be the change from first design to second design engine? My car definitely had the second design engine.
      • James F.
        • December 1, 1985
        • 596
        Re: Correct WCFB carbs for 56- Ed
        Ed, As I recall the difference in the first design is primarily found in the air horn details. The fuel intake air horn has a round "knob" where the 5/16" line and brass fitting enters. Also first design there us less "meat" around the choke housing bridge to the air horn . This if from memory and about all I'm capable of at this time. Good luck, Regards, Jim
