'67 ignition shield top bolt - NCRS Discussion Boards
  • Joseph E.
    • March 1, 2006
    • 175
    My '67 L79 is missing its bolt that secures the top ignition shield to the wire support. Can any of the members tell me what is the correct headstamp to look for regarding this application (RBW, E, anchor)? Thanks for any help offered.
    Joe #45420
  • Peter L.
    • May 31, 1983
    • 1930
    Re: '67 ignition shield top bolt
    Joe - RBW on my early 67 base motor car. Don't now that others are not "correct." Pete
    • Gerard F.
      • June 30, 2004
      • 3803
      The 67 Judging guide says "Some known headmarks are "E" and "L" "
      The repro, on the left in the picture, has an E
      My original for a 67 base engine car is EL with 4 circles. After I bought the repro, I found my original in the bottom of my 1970's toolbox. A lot finer detail than the repro, replated it of course.
      There is probably a few other correct head markings from different vendors.
      Jerry Fuccillo
      #42179
      Jerry Fuccillo
      • Peter L.
        • May 31, 1983
        • 1930
        Jerry - Would you do a photo of the underside of the bolt(s) showing the integral lock washer? Thanks, Pete
        • Jay G.
          • August 31, 1993
          • 398
          Paragon sells the best repo I've found. $2.00
          • Gerard F.
            • June 30, 2004
            • 3803
            Pete,
            Couldn't find the repro E bolt (Paragon), but I knew where the original bolt was.
            Here's a picture of the EL bolt in the picture above:
            Side:
            Bottom:
            Jerry Fuccillo
            #42179
            Jerry Fuccillo
