What is correct color of 1967 engine compartment - NCRS Discussion Boards
  • Jim Hansen
    1967 Corvette Roadster. I am in the process of preparing my engine compartment and underside hood for painting. The question is, what color? I purchased Semi-Gloss Black from Long Island Corvette Supply. Is this right, or should the color be a bit duller, like a satin black? Thanks for your help.
    Re: What is correct color of 1967 engine compartme
    Jim -
    The engine compartment blackout is more of a semi-flat than semi-gloss; kind of an "eggshell" black, if you will. John Deere "Blitz Black" or Krylon #1613 "Semi-Flat" are about as close as you'll get, IMO.
    • Jim Hansen
      John: Thanks a lot. Also, what do you know about the water pump? The NCRS book says its in place when the engine is sprayed. Does that mean that the whole thing is orange, or is it a base color with possible orange overspray? Thanks so much.
      • Bill Clupper
        whole thing is orange with the exception of the shaft and the hub where the pulley was bolted. this area was covered.
