67 small block starter solenoid number - NCRS Discussion Boards
  • Mike E.
    • February 28, 1975
    • 5134
    What is the correct solenoid number that mates with the 1107320 starter for 67 small blocks? (base motor, for what it's worth)
    Re: 67 small block starter solenoid number
    Mike-----
    Most likely, GM #1114356. However, several other numbers may be found on these solenoids. There were several different stamped numbers that all represent essentially the same solenoid. Why this was done, I have no idea.
    • Kirk McHugh
      SOLENOID
      1114344
      brown Bakelite end cap
      Delco
      Made in
      USA
      Remy
      R S
      That is what is on my 67 solenoid which is mounted to an original starter with this on it.
      1107320 7 B 7 (February 7, 1967)
      DELCO-REMY U.S.A.
      4 A
      Hope that helps.
