With the help of members of this board I found the source of my non functioning headlight warning lamp. I traced it to the firewall plug to the fuse box. After removing the plugs (took them both off to inspect and clean with electrical parts cleaner) I found that the pin for this circuit on the fuse box side was partially bent over and pushed in thus no contact. I pulled it out and straightened it with a pliers. Cleaned things up and plugged things back together and the circuit now functions. All I need now is to get a 257 bulb as the one in there was not a flasher. I couldn't find a GE one but one local supplier has a Wagner 257. Are all 257 bulbs regardless of brand flashing bulbs?
Thanks again to all that responded.
Wayne
Wayne
