My 57 has no power under load. Engine rebuilt with 500 miles on it. Carbs just rebuilt and while engine no longer sends "smoke" out the exhaust it still has no power under load. Clearly I am using the wrong Corvette restorer. But, that aside, I need your help in figuring out what is wrong.
Rebuild of engine seems fine, I had it inspected by NCRS judge before purchasing a year ago. My local Corvette restorer in New Milford, CT rebuilt the carbs to solve the lack of power. He thought car was perfect, not so. Still will not climb even the slightest uphill without down shifting more than necessary and eventually having to let the clutch slip in and out to inch your way up even a modest incline. The carb rebuilt eliminated the smoke. Plugs with 500 miles on them after rebuild were full of carbon and were replaced.
Curiously when driving at modest speed (35mph) on level road in 4th gear it will accelerate beautifully. But, if you down shift it hesitates and NEVER gets full power in any of the lower gears. Only 4th gear seems to act normally.
Can it be something in the spark/electical system? The spark may not be advancing properly under certain conditions?
Aside from finding someone else to work on my car, it is best if I at least know what needs to be done even if someone else does the work for me. So, any help you can give me in diagnosing the problem would be much appreciated.
Jack Farley
jufarley@optonline.net
Jack Farley
