My car was restored about 15 years ago but driven little. The nose was fine when I bought it 2 years ago, but after 5,000 miles of driving the nose has started to droop a bit as evidenced by a very slight telltale bulge above the front wheel wells.
Before attempting a fix by shimming the rad support, I removed the bumpers to free up the body from the frame. I also loosened the radiator support bolts. In jacking on both sides of the rad support I noticed that instead of the radiator/body being raised, the entire front end of the car was coming off the ground in one piece. Obviously not good.
I see that the fan shroud is connected to both the radiator mounting and the frame but I find it hard to believe that there's enough strength there to raise the entire front of the car with no slop.
Where am I going wrong?
Dave.
Dave.
