I HAVE AN EARLY FUEL CAR SERISL #00013 - 1961
MY QUESTION IS THE ONLY NUT PLATE ON MY CAR WAS FOR THE TOP MOUNTING OF THE FUEL INJECTION AIR CLEANER - THE PLATE THAT GOES BEHIND THE WINDSHIELD WEASHER VACUUM TANK MEASURES 1" BY 3.825" AND IS ABOUT .098 THICK- THE ONE BEHIND THE J STRAP IS 1.800" LONG BY 7/8TH WIDE - AND IS .250 THICK - IT HAS 2 RIVET HOLES AND 1 HOLE FOR THE STRAP- MY QUESTION IS WHAT KIND OF RIVETS WERE USED- WHAT HEAD CONFIGURATION - I TOOK THER PLATE MEASUREMENTS IN PLACR WITH VERNIEE CALIPERS IN PLACE SO THE DIMENSIONS ARE NOT 100% BUT CLOSE. DO YOU THINK A LAZY WORKER NEGLECTED TO PUT THE PLATES ON MY CAR - I HAVE SCENE A 60 FUEL CAR MISSING THE PLATES ALSO. I WOULD RATHER HAVE THE PLATES FOR OBVIOUS REASONS. DO YOU THINK I SHOULD ADD THE PLATES?? ALSO THE J STRAP FOR THE LEFT SIDE FRESH AIR HOSE I WOULD LIKE A MEASUREMENT FOR LOCATION
