What are the typical headmarkings on the original bolts used to attach the exhaust hangers to the mufflers and to the frame?
original bolts used for exhaust hanger...
Re: original bolts used for exhaust hanger...
Hi Rob, checked my notes on my 64 SN 8477 and the bolts were UR marked. Also the same bolt used to hold horn on if you have an original there. The bolt PN 122007 was very common and used else where so maybe you can find one still in place.
Dan1964 Red FI Coupe, DUNTOV '09
Drove the 64 over 5000 miles to three Regionals and the San Jose National, one dust storm and 40 lbs of bugs!- Top
I see now that the assembly manual shows same bolt used to attach the radiator shroud to the top mounting bracket. That bolt is marked RSC on my car. Looks like quite a few different marked bolts would be considered correct....Thanks.- Top
