clock and radio in my 64 vette - NCRS Discussion Boards
  • Gina P.
    Infrequent User
    • September 30, 1998
    • 23
    Hey out there,
    my radio just quit working in my 64 vette - I know there are ads in the NCRS publication as to where to send it, anyone have any recommendations? Also, I want to fix my clock which has never worked. I have heard pros and cons about replacing clock vs. fixing the original one. Would love to hear from anyone with suggestions and advice. Thanks for your time and input.. Gina
  • Alan Drake
    Re: clock and radio in my 64 vette
    I had new insides done to my clock and asked that the rebuilder not touch the face. My concern was that a new clock would stand out from the instrument panel and just look "new" the only problem I have with the mechanical clock is when the battery is disconnected the clock will not start back up. Returned it, got back, but still the same. So they can be a pain, must remove and shack it to start it. Have since added a 2 amp by pass circuit to battery switch to keep clock running all the time.
    • Dick W.
      • 10483
      I have had limited sucess starting a clock by pulling on the stem and then releasing it while it is fully extended. The snap will sometimes start the clock
      Dick Whittington
      • William L.
        • December 1, 1988
        • 944
        Gina
        Try giving Elmer Hoeferlin a call, PH# 636 926 2267, He has repaired several mid year radio's for me. His price has always been fair and the radios have worked like a champ.
        Bill
        Bill Lacy
        1998 Indy Pacecar
        • Kent K.
          • December 1, 1982
          • 1139
          Gina,
          I have used Roger at www.corvetteinstrumentservice.com successfully in the past. Roger cleaned and lubed my '67 clock in 1993 and it still runs true today.
          Good luck, Kent
          Kent
          NCM Founder - Member #718
          • Gina P.
            Infrequent User
            • 23
            Thanks Kent, I'll look them up. Appreciate the help. Gina
            • Gina P.
              Infrequent User
              • 23
              thanks for the idea for the 2 amp bypass, great suggestion! thanx again.
              • Gina P.
                Infrequent User
                • 23
                Thanks Bill, I will call him right now. Gina
                • David W.
                  • December 1, 1999
                  • 272
                  I can't recommend Corvette Specialties of Maryland enough. First class work at decent prices. I had great experience with them on my '64 clock and then the wiper motor. The advertise in the Driveline and have a website with rates.
                  • David W.
                    • December 1, 1999
                    • 272
                    Be careful with Roger's. I had a disaster with him several years ago. There were a lot of other bad posts at the time. Perhaps he has improved but check with others on the Board first.
                    • Kent K.
                      • December 1, 1982
                      • 1139
                      Please do not confuse Roger's Clocks with Corvette Instrument Service. I read almost all the posts on this board and have yet to read one negative comment about Corvette Instrument Service owned by Roger Scott.
                      Regards, Kent
                      Kent
                      • Gina P.
                        Infrequent User
                        • 23
                        are you referring to Roger Scott? I spoke with him today and was going to mail the clock down to him. Please tell me about the pitfalls. Or should I just replace my clock with a quartz? Thanks.
                        • Gina P.
                          Infrequent User
                          • 23
                          thanks for the clarification. I was impressed with Roger Scott after speaking with him on the phone today. Thanks.
                          • David W.
                            • December 1, 1999
                            • 272
                            Kent,
                            Yes I did confuse Roger's Clock with your recommendation. I saw the word 'Roger' and reacted. Sorry about that.
                            • Kent K.
                              • December 1, 1982
                              • 1139
                              Gina,
                              If you plan to have your Corvette judged, do not replace the original movement with a quartz movement. The factory movement depends upon your battery so, if you use a battery cut-off switch, it won't work when the battery is being saved. Don't worry, it'll work after Roger at CIS is finished with it.
                              Regards, Kent
                              Kent
