I have the 3 piece lower radiator shroud. It appears original. On the lower center piece, it has two holes for bolts that bolt to the front crossmember. There are also threaded holes in the crossmember. The repos (and assembly manual) do not appear to show these 2 bolts. It appears that this center piece simply screws to the 2 other side pieces and hangs in the center. Is this something that was added later by a prior owner, or does the lower center panel actually bolt to the crossmember with 2 bolts?
Thanks in advance,
Dave
Thanks in advance,
Dave
