boden cable source - NCRS Discussion Boards
boden cable source
  • Mike M.
    • May 31, 1974
    • 8365
    boden cable source
    looking for a source for new bowden cable housings . NAPA etc have generic throttle cable asemblies but their products have an OD of about .150" whereas the c-1 cables(Hood release on a 57 in this case) have an OD of .185". thanks, mike
  • Rob Dame
    Re: boden cable source
    Don't know for sure but maybe a farm implement place or a place that repairs larger mowers or small tractors
    • Roy B.
      • February 1, 1975
      • 7044
      Try a set of choke cable assy. Are you replaceing the hood pull cables inner and outer housings?
      • Wayne W.
        • April 30, 1982
        • 3605
        Mike, There is a guy in MD that makes them out of SS, and they are about the same size as the 50s Chevy stuff. I have the information at the shop. Will get it for you tomorrow if that is what you want.
        • Mike M.
          • May 31, 1974
          • 8365
          thanks wayne. awaiting the maryland fella's contact info. mike
          • Dennis A.
            • April 30, 1999
            • 1010
            Mike...
            Try www.inlinetube.com; Never used them, but they have GM cables used in hot-rods..
            • Mike M.
              • May 31, 1974
              • 8365
              thanks dennis. tried them without success. mike
                Try...
                loading your Google search engine with the correct spelling of the item (Bowden cable) and you should get a jillion hits, Mike....
                • Edward M.
                  • November 1, 1985
                  • 1916
                  Mike;
                  0.185 is pretty close to 3/16 (0.1875). That sound about right?
                  • Doug Flaten
                    I was looking for the internal wire for some and I found some at a lawn mower supply house. Not sure about the diameter though. You could also have some luck at old Motorcycle parts vendors. My old Harley had Throttle and spark Bowden cables. I think there are two different sizes on the Harleys.
                    • Mike M.
                      • May 31, 1974
                      • 8365
                      jack and ed: google search yields lots of plastic-wrapped bowden cables. 3/16" is about .184". thanks guys. still lookin. mike
                      • Edward M.
                        • November 1, 1985
                        • 1916
                        Does this help you any? Looks like both lined and unlined bowden cables.
                        http://lexco.thomasnet.com/viewitems...bowden-conduit
                        • Mike M.
                          • May 31, 1974
                          • 8365
                          looks promising ed. thanks, mike
