71 idler assembly question - NCRS Discussion Boards
  • Kathy Morris
    In the process of restoring a 71 454 4 speed convertible without air. It currently has the idler assembly on it. Is that correct? An NCRS judge friend could not confirm that. Seems that we only know of that being on big blocks with air. Any thoughts?
  • Tom L.
    • May 7, 2007
    • 438
    Re: 71 idler assembly question
    My 1970 454 w/o air does not have an idler pully assembly. The AIM for 1970 shows an idler pulley with air only, none w/o air. I would check the 1971 AIM to be sure.
      Kathy-----
      1971 LS-5 without C-60 did not originally use an idler pulley. Could the car have originally been built with an idler pulley? Yes, it's not beyond the realm of possibility that a factory mistake occurred. However, it's certainly not typical of factory production. Unless one has excellent proof to the contrary, that is the basis on which the car will be judged.
      If the idler assembly was added post-PRODUCTION, why would someone have done that? Very simple. By adding the idler assembly one converts the normally captive inner belt (which is one ROYAL PIA to replace) to a "3 point" belt with an adjustment at the idler. This makes belt replacement "INFINITELY" easier. Aside from issues of correctness, I would leave that idler right where it is.
      • Kathy Morris
        Thanks everyone. This was exactly what I was looking for.
