I just spent several hours going over archives for some questions. I answered some but now have others.
1. Spark plug shields. My car is a late (last month) LT-1. Currently there are no spark plug heat shields. (Sometimes called inner shields) In the archives I read that these were concelled in late 70 but am unsure if this was in reference to the outer ignition shield or the inner heat/sperk plug shield. Could someone clear that up. Should I have all 4 inner heat shields on a late 70. Also missing and not sure if I am supposed to have are the 2 hole plug wire grommets, two to the oil pan and two to the block, as well as the 4 hole inline grommet at the bottom of the ignition shielding at the rear of the block. Should I have all of the above.
2. Thermostat housing. Mine is orange on an aluminum manifold, should be natural aluminum, no? The two bolts attaching the housing are different. The right one is a stud/bolt, with unused threads above the bolt head, while the left (driver's) is simply a bolt.
I have several other questions, but this is a start.
