I am cleaning a survivor 1967 and I find the job number as L296. I have never seen a job number with a letter as well as the numbers. This appears very clear both on the firewall passenger footwell and the rear bulkhead. It is in yellow marker. Is the use of a letter very common.
1967 Job Number
Re: 1967 Job Number
Jim,
A.O. Smith body cars have a letter designation followed by a three digit sequential running 1-500. So the job numbers ran A1-500, B1-500, C1-500, etc. You may want to check the archives as there is quite a bit of info posted on AOS job numbers. Hope that helps.- Top
From my June, '67 A. O. Smith body
This is located on the rear bulk head just ahead of the gas tank. The same L383 was also written in yellow grease pencil on the engine side of the lower passenger floor board. "383" was also written in red grease pencil on the steel horizontal dash support (driver's side).
Hope this helps.
Tony
Attached Files- Top
My AOS Z Bar number
As Wayne said, on the cross-brace behind the dash cluster (on my 65 AOS body car):Attached Files65 MM Convertible, L76 (365 hp)- Top
