C3-1971 LT-1 - NCRS Discussion Boards
C3-1971 LT-1
  • Pete Schick
    C3-1971 LT-1
    Do the doors need to be removed before you remove the body from the frame?
    Thanks, Pete
  • Mike G.
    • July 31, 2002
    • 709
    Re: C3-1971 LT-1
    no, its better to leave them on and closed.to much body flex without it.
    • Pete Schick
      Re: C3-1971 LT-1
      Thanks, Do you have any suggestions or "gotchas" to look out for? Pete
      • Mike G.
        • July 31, 2002
        • 709
        Re: C3-1971 LT-1
        yes, make sure you pull the rear bumpers off first. you also have to pull the steering column out. its not that bad a job. i helped a friend pull his 70 body 2 weeks ago. it takes a few hours or so.
          Re: C3-1971 LT-1
          Be sure and rig up something to support the extreme front of the nose - there's a lot of weight out there, and the cantilevered load can shear the bond at the cowl.
          • Pete Schick
            Re: C3-1971 LT-1
            I've cut the pieces out according to Noland Adams body lift work book. Now I
            just need to put it together. Thanks for the advice. I'm beginning to realize
            how much of the work needs to be done by me and not a shop due to sheer time
            involved and the expense of using a shop. I do know that I can't do everything
            and the advice available from this organization is priceless.
            Thanks Again, Pete member #48271
            • Verle R.
              • March 1, 1989
              • 1163
              Restoration costs
              Pete,
              You have discovered on your own what a lot of people only discover after their car is in a shop and they start getting bills for work performed. Then when they go look there not a lot of obvious progress. Not all shops are ripping you off. There is a lot of "small detail" work that just doesn't appear to be much but takes a lot of time if it is done right.
              There was a thread earlier about restoration cost. This is a problem when estimating the cost of a correct restoration. It is fairly easy to estimate restoration cost for major items; body/paint, frame/running gear, engine, transmision.
              Someone has to spend significant time locating and buying correct parts.
              It is not easy to estimate it the cost of repairing/replacing/restoring the parts when the rusted bolt twists off and you have to spend a lot of time carefully drilling out and taping the hole. Then you have to find a correct bolt to replace the broken one. Etcetera, etctera, ad infinitum.
              Once you have made your best guess, multiply by three and you will be low.
              Verle
              • Mike G.
                • July 31, 2002
                • 709
                Re: C3-1971 LT-1
                if you have access to a car lift it works better than a smaller engine hoist.
                • Pete Schick
                  Re: Restoration costs
                  It makes you wonder how much the car is worth after your done when your looking at what you've spent or about to spend. I guess I'll find out somewhere down the road....
                  Thanks, Pete
                  • Pete Schick
                    Re: C3-1971 LT-1
                    We happen to have one...
