C1 foot pump rubber cup
  • Roy B.
    • February 1, 1975
    • 7044
    #1
    Some one in a later posting asked about finding a foot pump rubber cup.I don't remember what year they had but there is a difference between 55 and 56-57. If you look at the pic's the 55 R/S is a short rubber cup while the 56-57 L/S is longer, so make sure your getting the one you need that is now on e-bay which fits a 56 to 57.
    The one shown is not Corvette because it has a bracket but the cup can be removed from it to use on Corvette . These are vary hard it find. Hope this helped some one! This is a good example of locating parts from other Cars.
  • David B.
    • August 1, 2004
    • 330
    Re: C1 foot pump rubber cup
    Thanks Roy. I appreciate the knowledge being passed along.
    Do you have any advice concerning the rubber footpad for the '57 washer lever? I found something that looks pretty close but do you know of a crossover part from something that is correct?
    Dave
    Dave, 1969 427, 1957
    Previous: 1968 427, 1973 454
    • Roy B.
      • February 1, 1975
      • 7044
      Re: C1 foot pump rubber cup (Dave)
      It's a slip on , just about any foot pump GM or other wise will have the same rubber pad but not all . It's flat at the back and having what 3 ridges on the front.
      It's the 55 round rubber pad that would be super hard to locate, but again truck used the same unit as Corvette 55.
      I'm not pushing E-bay but when I find a super rare part for a C1 I like to post it to help C1 guys & gals.
      • Steve H.
        • November 1, 1996
        • 118
        I also have been looking for the foot pad. Would like to know of some possible sources.
        Steve
        • Roy B.
          • February 1, 1975
          • 7044
          here guys! foot pump rubber pad
          OK you two guys need to look in e-bay saying (washer pump foot) click on lower post , GM and other makes made foot pump that may not fit your Corvette but are OK to get parts from . This one is from Chevy ! As I say people go to Chevy or olds for many parts and for get Corvette.
