C1 Interior Fan Switch- What's this? - NCRS Discussion Boards
  • Richard P.
    • May 31, 2002
    • 190
    The fan switch from the console on my 61 has a coiled wire assembly on the back. What is it? One end of the wire is riveted to the switch housing and the other end has a crescent shaped bracket that just hangs loose. I suspect that this bracket should be attached, but where. Thanks for your help.
  • Joe Maulsby
    Re: C1 Interior Fan Switch- What's this?
    The coiled wire allows for 2 fan speeds, like a rheostat on a light switch. It should not be haning loose, but mounted to the back of the switch.
    • Roy B.
      • February 1, 1975
      • 7044
      Re: C1 Interior Fan Switch- What's this? *NM*
      • Richard P.
        • May 31, 2002
        • 190
        Thanks Joe and Roy, you guys are great!
