65 frames ...... - NCRS Discussion Boards
65 frames ......
  • Donald S.
    • January 23, 2008
    • 183
    65 frames ......
    i have been told that there are differences between small and big block frames but cant find anything about what they are .... also how are the holes made for the bolts on a bb battery tray are they inserts like on the right side or are they drilled and tapped ... and on bb frames do they still have the inserts in the frame for the right side tray....thanks don...
    Re: 65 frames ......
    don-----
    Early 1965 frames (prior to the time that the L-78 was introduced) may lack the relief in the front crossmember for big block balancer clearance. However, most 1965 frames, big block or small block, have the relief.
    Some L65-67 small block frames MAY lack the holes and weld nuts for the rear stabilizer shaft "U" brackets. I think that most, if not all, L65-67 frames have the holes and weld nuts, though. From 1968 on, some small block frames did not have the holes and weld nuts.
    As far as I know, the inserts were used for battery tray retention bolts in the frame for all applications.
    • Donald S.
      • January 23, 2008
      • 183
      Re: bolt holes
      the car was built on july 13 it has the dip in the x member and the captive nuts for the rear sway bar .... but it also has nut inserts in for battery trays on both rt and lft rails so is this normal ??? or should it only have inserts in one of the two rails???and not both...
        Re: bolt holes
        don-----
        The inserts were installed by the frame manufacturer, A.O. Smith. They would not have known whether any particular frame was destined for a big block or small block. So, they undoubtedly installed the inserts for both battery mounting possibilities.
        • Donald S.
          • January 23, 2008
          • 183
          Re: bolt holes
          so having the inserts in both sides is quite possible or is this an oddity??
          • Wayne M.
            • March 1, 1980
            • 6414
            Factory inserts on RH side only
            and for 396 or air-conditioned cars, should show no evidence of ever having a bolt threaded in.
            The LH battery tray on C60 cars and L78 cars were drilled and self-threading bolts were installed, on a per-application basis -- no inserts.
            • Donald S.
              • January 23, 2008
              • 183
              Re: Factory inserts on RH side only
              so the rt side inserts should have no threads ???? or threads but no marks arround the edges from the tray or bolts??
              hmm ... how in the heck does my frame have inserts in both rails the inserts are different mebey they were installed as a repair for stripped bolts at some time
              • Jason B.
                • April 30, 2004
                • 29
                Donald, my 65 was also built right around the time your was. Whats the last number of your VIN? I have 23060, a small block roadster.
                Jason
                • Wayne M.
                  • March 1, 1980
                  • 6414
                  LH's were probably added to correct stripped
                  .... threads. You have to be very careful when torquing these 6 bolts (only 6 to 8 ft.lbs), as there aren't many engagement threads in the thickness of the frame.
                  • Donald S.
                    • January 23, 2008
                    • 183
                    vin ends with 21679 bb 4 speed coupe
