65 L 78 casting # - NCRS Discussion Boards
65 L 78 casting #
  • Donald S.
    • January 23, 2008
    • 183
    65 L 78 casting #
    my 65 built july 13 the block has been decked so no ### it is a 962 block with the P beside the casting on the bell housing flange its dated d 5 but on the back of the block by the cam plug its cast
    HP
    PASS
    TRUCK in this configuration one above the other ... is this correct????????
    Re: 65 L 78 casting #
    don-----
    That's the one you should have.
    • Donald S.
      • January 23, 2008
      • 183
      thanks thought so but the truck casting thruogh me also would april 65 date on the blockbe correct for a july 13 build
      • Barbara S.
        • April 30, 1981
        • 599
        Does it have the gussets? *NM*
        • Donald S.
          • January 23, 2008
          • 183
          gussets?
          gussets where ????? in the lifter vally ??? ill go to the shop and look...
          • Barbara S.
            • April 30, 1981
            • 599
            Re: gussets?
            See the two vertical lines protruding in the front of the block? Those are the front gussets.
            • Donald S.
              • January 23, 2008
              • 183
              Re: gussets?
              yes it does ..... is that good or bad????
              • Bill W.
                • March 1, 1980
                • 2000
                396 cars with vins in the mid 17000 to early 18000 could be hi per or pass.. whats your vin ?
                • Donald S.
                  • January 23, 2008
                  • 183
                  vin is 21679 built july 13 block was cast on april 15 65
                    don-----
                    An April block casting date is well within the range of possibility for your car.
                    • Bill W.
                      • March 1, 1980
                      • 2000
                      An April block should be a pass. But a car built in July as late as 21679 should have a Hi per..That does not mean it couldnt happen .But I think if you trace the history you will find it lost its orig. block.
                      • Donald S.
                        • January 23, 2008
                        • 183
                        the block has all three hp pass and truck .... how would a person go about tracking the history in a us built car as there are no records and the car has no build sheet....
                        • Barbara S.
                          • April 30, 1981
                          • 599
                          GOOD. *NM*
