60 corvette windshield wiper transmissiom replacem - NCRS Discussion Boards
  • j t hamilton
    On my 60 corvette i need help replacing the wiper motor.I't has 4 lines that run to the base of the wiper motor.I do not know in which order to hook these lines up. My 60 model didn't have the wiper motor on it when i bought the car.you can contact me @1-731-423-8443 thank you
  • Bob Malone #35242
    Re: 60 corvette windshield wiper transmissiom repl
    Check your email
    • Ed Jennings
      Before you start installation, be sure that your transmissions are functioning properly. If you can't depressthe shaft and extend/retract the cables you won't be able to adjust them once installed. For that matter, you likely won't be able to install them in the first place if the cables won't extend to the maximum distance. Also be sure the shaft on the center drum is not cracked or broken. This is one of the weak links in the system.
