1963 oil canister - NCRS Discussion Boards
1963 oil canister
  • nancy charles
    1963 oil canister
    WHAT IS THE TRICK TO DISASSEMBLY of the bolt in the can ? thanks
  • Peter L.
    • May 31, 1983
    • 1930
    Re: 1963 oil canister
    The bolt is staked just above the "mushroom" shaped retainer piece to keep the bolt, retainer and spring from coming apart when the canister is not installed or is being removed. I use a thin flat screw drive to expand the top of the retainer piece at places corresponding to where the bolt is staked and then remove the bolt. Pete
    • Andy C.
      • May 31, 1987
      • 71
      Hello; You can grind the pinched metal on the main bolt away to take the bolt out along with the spring, washers,etc. Once you have the parts out, you can machine a groove in the bolt at the same spot where the pinches were and re-assemble using a C-clip. Andy
