Trying to get the engine compartment wiring routed correctly.
1) Under the hood, there is a red wire that runs out of the firewall to the voltage regulator. Is this the only that runs through the clips to the regulator. The clips seem huge for just this single wire.?
2)Also, are the wiring harness clips from CC intended to be used on the tach cable, speedo cable, etc. Or is there a different style clip used for these large cables?
3)The engine harness that goes to the starter..... the clips that hold these wires under the windshield, how are they attached, as there does not seem to be any holes for screws?
