65 365 Air Filter Element - NCRS Discussion Boards
  • Keith M.
    • November 1, 1976
    • 205
    Guys, I am in the procress of trying to buy a 1965 365HP and was wandering what is the correct AC element for this car? Is it like the 63 340 HP? If I get the car I will invest in a judging manual. Thanks Keith
    Re: 65 365 Air Filter Element
    Keith-----
    It's the same as 63 340 hp.
    • John S.
      • September 30, 1997
      • 263
      Keith,
      The correct filter element is AC A165C. It's a oil wetted polyurethane foam over perforated steel screen Same element is used on the '63 340 engine.
      • Keith M.
        • November 1, 1976
        • 205
        Joe and John,
        Thanks for your input. Both of you say it is like the 63 then I am up to speed. Now which of you have and original screen and element? Now that I am looking for one for a 63 and now a 65. Keith
          keith------
          The original screen and element were discontinued a LONG time ago. About 40 years ago, as I recall.
            Plus...
            any 'originals' that you find will have suffered time-deterioration of the foam. It has a distinct shelf life...
            Reproductions use foam with a slightly different color, thickness, foam aeroation density. Plus, to my knowledge, NOBODY has bellied up to the bar to take a reproduction license from GM so they can make a 'correct' reproduction of the foam replete with the AC embossed part number...
              Re: Plus...
              Paragon has just the foam element with the correct extruded shape (#1004), just the screen (#1003), and the foam element & screen assembly (#1005K); don't know if it has any other markings on it. They also have the functional paper replacement element.
              • Keith M.
                • November 1, 1976
                • 205
                Joe, Thanks, being I have never been around the 365 AC assemby I assume once the element and screen are on the car one is not able to tell whether they are repro or original. I would slso guess NCRS would take them off the car and be able to tell correct? Long Island is showing a filter and screen and he specifies one must be used with the other. Do you have any input here? Tanks.
                • Mike M.
                  • September 30, 1999
                  • 710
                  Unless they changed the screen
                  The screen did have the wrong size holes in it. not sure if they have been changed.
                  • Keith M.
                    • November 1, 1976
                    • 205
                    Re: Plus...
                    Jack, sounds like the 3x2 AC element situation. Thanks
                    • Keith M.
                      • November 1, 1976
                      • 205
                      Re: Unless they changed the screen
                      Mke, you would not happen to have the dimensions on the originals and the repro would you? Thanks
                      • Mike M.
                        • 710
                        Keith From the judging guide. Original perforated screens have larger diameter holes than current reproductions screens. This may be determined by the width of metal separating the holes. This distance on original screens measures approximately 1/32 inches and current reproductions measure approximately 1/16 inches.
                        • Dale S.
                          • November 12, 2007
                          • 1224
                          Why do these company spend the time and money to build and sell something that is not exactly like the original? Why not do it right the first time? I have bought so many repro parts that are not even close to the original that I am replacing. i just put my original used part back on. I have a box of repro parts that I am going to sell on ebay because it is so junkie I would not put it on my 67. Dale
                          • Keith M.
                            • November 1, 1976
                            • 205
                            Mike, Thanks for the information.
                            Keith
                            • Keith M.
                              • November 1, 1976
                              • 205
                              Dale, I bet it has to do with cost and return. I would also guess this has a lot to do with the reason why someone paid $80.00 for two wing nuts to hold the battery down. Keith
