C1 GM Front/Rear Emblem Bezels - NCRS Discussion Boards
  • Ted S.
    • January 1, 1998
    • 747
    I just opened 3 new GM bezels for the front and rear emblems and none of them have a large enough ID to slip over the plastic emblem. To make sure I took one of the originals and it slips over fine. Since I'm getting ready for the plating shop I thought about using a sanding drum on my die grinder to open it up a little and have them replated. I'd use the originals but the have broken pins. Anyone else have this problem? If so what did you do? Thanks, Ted
  • Howard M.
    • June 30, 2000
    • 124
    Re: C1 GM Front/Rear Emblem Bezels
    Ted:
    Had the same problem with the bezels for my 60. I did the same thing your thinking of doing with the drum sander. Be sure you remove enough material so that when replated, there is still clearance.
