How many wire lugs should be on the blower switch and where do the wires go?
My switch has 4 positions for lugs: B and 1, 2, and 3. The 1 lug is broken but is there. The 2 lug is either completely broken off or was never there. The factory wiring diagram and Dr. Rebuild's (GREAT help by the way) are a little vague in that they only show a 14 ga. brown wire marked "Heater". Am I correct in assuming the B lug goes on the Fan(Blower) wire? Where does the brown "Heater" wire go on the switch? Are the other 1 or 2 lugs used? By the way, thanks Roy, for the picture of this switch you posted. Once again, thanks for all the help.
