Rebuild Kit Fuel Pump 65 350/327 - NCRS Discussion Boards
  • William H.
    • March 1, 1999
    • 249
    Hello All,
    My 65 350hp/327 has an original fuel pump in need of a rebuild as it is leaking gas into the oil pan. Does anyone know where a rebuild kit can be purchased? If not do you know if I could buy a new AC replacement and move the necessary parts from it to my original pump? Just wondering if anyone has tried this?
    Thanks in advance
    Bill
  • Eugene B.
    • May 31, 1988
    • 710
    Re: Rebuild Kit Fuel Pump 65 350/327
    Bill,
    When the fuel pump leaks gasoline into the oil pan, it is usually a ruptured diaphram.
    Both Long Island Corvette and Paragon have rebuild kits for your fuel pump. If I were you, I would rebuild my original (that's what I did on my '65) instead of going with a new replacement.
    Good luck,
    Gene
    • Loren L.
      • April 30, 1976
      • 4104
      NAPA? *NM*
      • Larry M.
        • January 1, 1992
        • 2688
        Bill:
        Call Arthur Gould Rebuilders in New York if you do not want to do the rebuild yourself. (631) 269-0093. They have an excellent reputation for rebuilding water pumps and fuel pumps.
        Paragon and LICS carry rebuild kits.
        Larry
        • John D.
          • December 1, 1979
          • 5507
          ZIP Products has a good kit also *NM*
