Signal Flashers Help - NCRS Discussion Boards
  • Paul M.
    • November 1, 1987
    • 142
    Trying to find the correct aplication for the following flashers.
    Tung Sol # 322 and 223. Signal stat #ZN332. Stat Co. #143, 144, and 145.
    Thanks in advance. Paul
  • Dave S.
    • August 31, 1992
    • 2918
    ZN332 is 61/62 Corvette *NM*
    • Peter L.
      • May 31, 1983
      • 1930
      Re: Signal Flashers Help
      Paul -
      Signal-Stat flashers were used by GM and Ford and probably Chrysler. As far as, I know applications were specific to the number of lamps in the turn signal circuit and this in turn dictated which cars they were installed in so any 1965 GM or Ford vehicle with 3 lamps in the turn signal circuit might have a #145 installed in it.
      #143 - turn signal flasher circa 63-64 production years - all w/ 3 lamps
      #144 - turn signal flasher circa 65 - early 70s production years- all w/ 2 lamps
      #145 - turn signal flasher circa 65 - early 70s production years- all w/ 3 lamps
      Pete
