1971 Trans Numbers - Confirmation? - NCRS Discussion Boards
  • Greg F.
    • February 21, 2007
    • 253
    All,
    I have the following numbers from my transmission
    Muncie: M-20 (Wide Ratio) (2.52:1 low)
    Transmission ID: P1B12A C11S109990 (Muncie, 1971, Feb 12th, M-20)
    Main Case: 3922566
    Extension Housing: 3978764
    Side Cover: 3952648
    I found this number on the passenger side of the main case. What is this number?
    Another # on Main Case: 3088386
    Re: 1971 Trans Numbers - Confirmation?
    Greg------
    I think that you've either incorrectly read or typed the main case part number. The main case part number should be 3925661. I've never seen or heard of a Muncie case of 3922566. I believe the 3088386 is a patent number.
    • Greg F.
      • February 21, 2007
      • 253
      You're correct, Joe. thks! *NM*
