Stripping wheels
  • Chris L.
    • November 1, 1998
    • 266
    Stripping wheels
    What is the best method to remove clear coat from and aluminum wheel. These were coated years ago and need to be restored. Thanks
  • Tracy C.
    • August 1, 2003
    • 2739
    Re: Stripping wheels
    Strip the clear coat using aircraft stripper and follow with a lacquer thinner wash.
    good luck,
    tc
    sorry for the blurry pic...it was nippy the night I took it..
    • Chuck S.
      • April 1, 1992
      • 4668
      For stripping alloy wheels, any chemical paint stripper from Home Depot will probably work just fine...you have no worries about the stripper soaking into fiberglass.
      I used Kleen-Strip KS-3 Premium Stripper in the gold can, and it worked like a charm. I only did the fronts and used less than a quart out of a gallon; use this information to buy what you need. It was kind of wierd when that clear began to wrinkle and bubble up...it looked like packaged tripe I used to see at the market. No...I never had it unless it was mixed into something (menudo?), but some people eat it.
