67 fan blade 427-400 AC - NCRS Discussion Boards
  • Rex T.
    • December 1, 1984
    • 455
    For 1967 427-400 with air cond, does it use a 5 or 7 blade fan?
    Rex
  • Kent K.
    • December 1, 1982
    • 1139
    Re: 67 fan blade 427-400 AC
    5 blade, 7 blade was replacement for those complaining about hot running conditions. Check the archives, this has been discussed at length.
    Kent
    Kent
    NCM Founder - Member #718
    • Rex T.
      • December 1, 1984
      • 455
      Thanks Kent. For some reason (probably operator error), I can never find what I am looking for in the archives.
      Thanks for your help. Rex
      • Peter L.
        • May 31, 1983
        • 1930
        Rex - As Kent indicated 5 blades is the winner. If you check the AIM, you'll find there is no "call out" for another fan blade assembly for BB C60 cars. As far as I know, all 67 BBs used the same fan blade assembly. Pete
