1957 Powerglide - NCRS Discussion Boards
1957 Powerglide
  • Mike N.
    • April 1, 2001
    • 110
    1957 Powerglide
    I have 4 1/2 quarts in the trans and can NOT get a reading on the stick.
    Picture attached............
  • Terry D.
    • May 31, 1987
    • 2690
    Re: 1957 Powerglide
    Mike
    If you had it rebuilt, it holds 9 quarts.
    • Terry D.
      • May 31, 1987
      • 2690
      Re: 1957 Powerglide
      Mike
      Sorry about the info, a 62 aluminum transmission holds 9 quarts, not sure if 57 holds that much, but probably more than 4. I'll check when I get home this afternoon if nobody else has chimed in by then.
      • Mike M.
        • May 31, 1974
        • 8365
        Re: 1957 Powerglide
        10 qts. mike
        • Don S.
          • February 1, 2000
          • 476
          Picture please Roy
          I have a dip stick pictured like the one in the post. I am told it is the wrong one for a 55. I now do not know what to look for. If you have a picture showing the handle as well i would appreciate seeing it. Thanks in advance
          • Roy B.
            • February 1, 1975
            • 7044
            Re: 1957 Powerglide
            9 quarts is correct and the stick is correct, yes some people think the 53 to 54 Corvette is correct (same as early 6 banger Car )but 55 up Corvette and Car V8 are the same stick in most cases till the cast iron PG was dropped. 53-54 has a different reading . Don't think it's mentioned in the JM. As many things ant.
            (by the way running about 1 quart low will not hurt the trans and stop the leaking and throw ups )
            • Roy B.
              • February 1, 1975
              • 7044
              Re: 1957 Powerglide
              This is a Corvette torque Convertor
              • Mike N.
                • April 1, 2001
                • 110
                Re: Picture please Roy
                You guys are GREAT!
                I will definitely have the car up off the ground this time.......I don't want the thing to shoot out like a rocket.
                I'm hoping the reason it is NOT engaging is because I don't have enough fluid. I sure hope you guys are correct about the 10 quarts. This trans was completely rebuilt before I installed it.
                I will take a picture of the dip-stick and posted.
                Thanks again.........I will keep you guys posted of my results. Right now I have to address the leaking and check linkage.
                  The 1957 Shop Manual says 4-1/2 quarts for a refill after normal change draining, the '57 Assembly Manual says 1.06 gallons (4 quarts) for plant fill, and the '57 owner's manual says 4-1/2 quarts for "sump refill" and 11 quarts for "total refill".
                  The 7-quart difference between "normal refill", "plant fill", and "sump refill" vs. the 11-quart spec is the fluid retained in the converter; the first three conditions all reflect a transmission that has been run previously (not a "dry" transmission).
                  • Mike M.
                    • May 31, 1974
                    • 8365
                    motor manual is where i got the 10 Qt figure. i'd go with john's #'s. mike
                    • Mike N.
                      • April 1, 2001
                      • 110
                      Thanks John........
                      I wonder if the specs are the same for a '57 car????
                      I guess I will find out very soon-
