Removing handle from hood release cable
  • John S.
    • August 1, 1990
    • 292
    Before I make a mistake has any one taken the handle off of a hood release cable on a 1957. I have had some that are loose and some one had put a pin threw it, but this one is tight. I want to rechrome the handle and the base and replace the cables. As always Thanks for any help john
    • June 1, 1974
    • 8288
    Re: Removing handle from hood release cable
    little heat usually loosens them up mike
    • Brad K.
      • September 1, 1990
      • 413
      The handle on my '59 came off in my hand after I pulled on it repeatedly after the spiral wound cables dried up. I was driving the car daily and did not clean and lube the cables regularly. A little bit of JB Weld and it's been fine for years.
