1970 - Diff assm by bolt - NCRS Discussion Boards
  • Stephen L.
    • August 29, 2007
    • 205
    hi all - don't have my aim handy so forgive not be able to cite the exact part...but on the bracket that attaches the nose of the diff to the cross member - there is the bolt at the cross member side and then 2 at the diff nose side - the top one of these, as i back it out, hits the battery holder - is there a trick to getting this out with the battery holder still in place? - thanks! - stephen
    Re: 1970 - Diff assm by bolt
    stephen-----
    Remove the snubber bracket forward bolt and the driveshaft. Then, you can lower the nose of the differential enough to remove the through bolt.
    • Stephen L.
      • August 29, 2007
      • 205
      thanks joe...as always...that bolt is out...so i will try what you said and let you know how it worked!
      • Stephen L.
        • August 29, 2007
        • 205
        thanks joe...as always...that bolt is out...so i will try what you said and let you know how it worked! to be clear...when you say lower...do you mean to hang on it a bit or do you mean undoing a bolt somewhere to lower it? - thanks! - stephen
          stephen------
          With the front bolt removed and driveshaft removed, the nose of the differential will usually naturally lower by enough to get the bolt out. If not, you can "pull down" the nose enough by hand to do it.
          • Stephen L.
            • August 29, 2007
            • 205
            thx joe - have the front bolt out and the drive shaft out - but don't have any play in the nose??? - are you assuming the diff is attached or unattached to the half-shafts? - thanks, stephen!
              stephen-----
              I've done it both ways. It might be easier with the half shafts out, though. Usually, you just need a small amount of lowering of the nose of the differential to get the bolt to clear. You do have the strut rods and bracket disconnected, don't you? If those are installed, you'll never get the nose to down.
              • Stephen L.
                • August 29, 2007
                • 205
                uhhh...sure i do...yah...of course...what you think i am...an ameteur or something...oh...that would be correct!!...i am an ameteur and a rank one at that...so, next the "struts" and the "bracket" will come out...i'll try again...if still no go, the half shafts...its got to tip a bit at some point...thanks again Joe! - stephen
