Hello -
I'm considering doing something I NEVER thought I'd do; try an oil additive to cure internal engine problem(s)!
I bought my '67 L79 about a month ago and have only driven it short distances 4 or 5 times at 35-40 mph while keeping it to less than 2000 rpm. The car was kept by a widow for about 17 years after her husband passed away, and apparently received very little attention during that time. The car is very original, complete and unmolested.
The engine exhibits symptoms of valve sticking; an occasional, sporadic backfire thru either the exhaust or the carb. Though this hasn't recurred, in one instance a lifter ticked for a few seconds after startup before becoming quiet.
The engine has fresh oil, but I'm considering trying Marvel Mystery Oil after searching this site and finding a few positive comments on it. Should I add it to both the crankcase and the gas tank? ....and in what proportions? ....or just follow the instructions on the can?
About 10 years ago a coworker who had a C4, and was knowledgable about tribology, routinely put something instead of motor oil (I can't remember what) into his crankcase at every oil change and then drove it briefly (an hour maybe) to clean everything out, before installing fresh engine oil. Anyone have any 1st hand knowledge (ie successful experience) with such a 'home remedy' for removing varnish/carbon buildups???
I don't want to damage the valuable original engine in this car, but would also like to avoid a teardown if possible.....
Thanks.
Bob S.
Thanks.
Bob S.
