66 SB exhaust manifold studs what length? - NCRS Discussion Boards
  • William G.
    • January 1, 1988
    • 220
    Can anyone tell me what the correct protrusion length is for 66 SB (I have an L79) exhaust manifold studs? I read that the right side should be longer to accomodate the heat riser. Thanks for any help.
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: 66 SB exhaust manifold studs what length?
    Bill -- I measured a '68 BB RH (828) manifold I have handy, with original studs still installed (would need a torch to remove). Should also be same stud as for SB's as the heat riser THICKNESS was the same SB or BB (but I believe the '66+ SB manifolds had dumps that were nominally 2" (versus 2_1/2" for hi-horse '63-65 and all BB's).
    Anyway; protrusion 2_1/2" exactly. Overall length of stud 3_3/64" (3.05")
    • William G.
      • January 1, 1988
      • 220
      Thanks for your help!! *NM*
