How should the fan clutch be stored? Mounting hub up, down, or sideways?
Fan clutch storage
Re: Fan clutch storage
Rev Mike, We covered this detail at a seminar not to long ago. Bill Calarico was putting on a wonderful seminar about clutch fans. Bill said that the best way to store them is just like Gary said. Store them like it would be mounted on the car. This helps prevent the oil from running out. John- Top
In the box, GM says 2 ways, depending on type
Sweitzer (bi-metallic strip) type says, ink-stamped right on the strip, "THIS SIDE UP".
Eaton (bimetallic coil) type has stamped on the face "STORE THIS FACE DOWN", in 2 places (at least on the later production).
And yes, vertical (as mounted on water pump hub) is also acceptable [and necessary], but not for long term storage, IMHO.
Just following instructions- Top
