57-65 FI question - NCRS Discussion Boards
57-65 FI question
  • Mike M.
    • May 31, 1974
    • 8365
    57-65 FI question
    anybody out there with a faily unmolested 57 to 65 FI, check the oil line that lubricates the FI ignition distributor. it runs from the 3 port distribution block that threads into the top right rear of the engine block to a 90 degree brass elboe on the back side of the distributor housing.Check and see if this steel line to the distributor is a copper coated line.Most , if not all repo distributor oiling systems that have been available for years are either non-copper coated steel lines or pure copper lines(magnet will differentiate).thanks, mike and the 56-57 judging manual revision team.
