Can someone (Joe?) provide the correct clutch fork part number for a '61 with an aluminum "553" bellhousing? I am getting ready to pull the works as one of the fingers of the fork spring broke. I want to be sure that it is the right fork before I bother to repair it.
My understanding is that there may not be a part number stamped on the fork. If that is the case, are there unique identifiers or critical dimensions that I can check?
Thank you,
Mike
Thank you,
Mike
