If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
Hello, I've been researching my '74 in the archives and found several posts that say the oil pan on 63-74 small blocks should drain from the rear. However the TIM&JG for 73-74 says it should drain from the driver's side.
Which is correct?
All 1973-74 Corvette oil pans, both big block and small block, used a REAR drain. Period. Some folks say that very late 1974 small blocks used the 75-79 style pans which did use a side drain. However, I've never seen a known case of it.
Except for 1975-79, all 1963-96 Corvettes used unique-to-Corvette oil pans. 1975-79 used, essentially, a passenger car pan although extra baffling was provided for L82's.
Thank Joe!
The one on my car drains from the rear, but I always suspected that someone changed it due to the close tolerance to the bellhouseing, good to hear its still the correct pan. I wonder if the people who write the judging guide are aware of the error, it could cause someone alot of problems if they try to put on a left side draining pan and want to have the car judged.
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
