The Tonawanda "180" block has the following stamped on the pad on the right front of the block : TIOOIEEH . Joe C. previously replied with the code sequence, but there are too many characters to fit the sequence. Can someone decipher this ?
Also, the intake manifold is 3844461 GM . It is apparently aluminum, since a magnet doesn't stick to it. Origin ?
