65 M 20 - NCRS Discussion Boards
65 M 20
  • Donald S.
    • January 23, 2008
    • 183
    65 M 20
    can some one help me with the assembly code please it reads P 09 12 im thinking 9 th month 12 day but what is the P for thanks
  • Rich Puleo
    Re: 65 M 20
    P is muncie.
    Rich
    • Donald T.
      • September 30, 2002
      • 1319
      Re: 65 M 20
      September 12 Muncie is correct. Assuming it is a 325 case, it would be for model year 64 or 65. So it could be 9/12/63 or 9/12/64. If the date code is located by the front cover is will be for model year 64. If it is located along the vertical rear flange, it will be for a 65.
      • Wayne M.
        • March 1, 1980
        • 6414
        and probably stamp surface looks like this
        Looks like a circular router was used to provide a flat surface. This appears to have started at SOP Muncie transmissions for '65 MY, when they switched from driver side cover lower rear corner ('63-64) to passenger side, as part of P-o-P introduction. Earliest I have noted is P0806 (August 6th). I haven't seen any later that Sept 16th, so far. At that point, they probably figured the grinding was unnecessary.
        BTW; P designates Muncie 4-speed for PASSENGER CARS. There were other Muncies: M = 3-speed truck; N = 4-speed truck.
        • Donald S.
          • January 23, 2008
          • 183
          Re: stamp surface looks like this
          stamping looks like this
          • Donald S.
            • January 23, 2008
            • 183
            sorry here it is
            • Wayne M.
              • March 1, 1980
              • 6414
              Looks like a Muncie assembled 12th Sept 1963
              for a 1964 model year car. Any VIN stamping on this trans case ?
              • Wayne M.
                • March 1, 1980
                • 6414
                Also, on RH side, does it say 'PAT.PEND' ..
                ... under the top line part # 3851325 ? If so, it's confirmation of an early 1964 model year.
