I have found one source of the loose steering on the 64. The rag joint
between the coupler halves is very worn and cracked. I see all the hot spots have a replacment for this including new studs and bolts. How hard is this to change? It looks like you would need to drill out the rivets and pull the steering colmn. Would it be just as easy to replace the entire coupler?
Bonus point question: Why are the studs a different size?
JMP
JMP
