I’d like to determine if the cam in my 66 327/300 hp 4speed roadster is the stock cam or a performance replacement. The engine was overhauled by a speed shop about 10 years ago (and the cam replaced) when the car was owned by the previous owner. There is no documentation that specified what cam was installed.
I’m trying to get the engine to idle smooth below 650 rpm. I’ve carefully checked the distributor map, VAC performance, timing and carb idle setting. I performed a vacuum leak test using the unlit propane torch method but detected nothing. Below 650 rpm, it will idle rough (mild vibration) and occasional surge +/- 50 rpm. I’m doing all of this in preparation for a PV where the book calls for a smooth hot idle speed of 500-600 rpm for the 66 base engine (327/300 hp).
Is there any way to determine what cam is in the engine short of engine disassembly and inspecting the removed cam?
Dave Kitch
33108
Dave Kitch
33108
