64 frame differences vs. 65 - NCRS Discussion Boards
  • Mike E.
    • February 28, 1975
    • 5134
    What are the differences between a 64 and a 65 frame other than that the 65 has the depression in the front crossmember for the big block? Is there any difference between a 63 and a 64?
    Thanks in advance!
  • Alan Drake
    Re: 64 frame differences vs. 65
    Mike, one difference is that early 64 frames (till 4/64) did not have the support bracket in the back corner of frame by body mount 3.
    • Wayne M.
      • March 1, 1980
      • 6414
      Another: depression to clear rear calipers in '65 *NM*
      • Mike M.
        • May 31, 1974
        • 8365
        63's differ from 64's in that former had no rubber body mounts so frame brackets for body mounts are welded higher on the 63 frame. 64 used rubber body mounts so brackets lowered on 64 frames the thickness of the rubber body mounts.also,63 e-brake hardware differs from 64 e-brake hardware. feel certain there are other dis-similar areas.mike
        • William C.
          • May 31, 1975
          • 6037
          Mike, there is also a rebound snubber that is outboard of the frame (rear) on '63-64 frames and it is moved to align with the pad on the trailing arm on the '65 up cars, just more of the needed adjustments to allow the use of Disk Brakes.
          Bill Clupper #618
          • William C.
            • May 31, 1975
            • 6037
            Re: 64 frame differences vs. 65 PS
            Also, 63 frames did not have the slots in the main frame rail as I recall, used on later cars for the rear mount for Sidepipes---working from memory now...
            Bill Clupper #618
            • David D.
              • 330
              64-64 used 2 additional center body mounts. *NM*
              • David D.
                • 330
                Correction 1963 and 1964!!!. *NM*
