If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
My original '75 steering wheel has become sticky on the black rubber/composite ring. It looks just fine, but feels sticky to the touch...like some oil based resin is seeping out. I tried mild soap and water and that seemed to help a bit, but when I picked it up yesterday from storage for installation (just finishing my restoration) it was sticky again.
Does the black material breakdown with age? What can be appiled to stabilize the wheel?
Tory
1975 Convertible
L-48, 4-spd, FE7, radio delete
Original owner
NCRS Top Flight Regional 2011, 2013
Dallas, TX
Tory, thats interesting, I have the same problem with my '75 steering wheel as well as the radio knobs. I have always wondered what the heck it was, as cleaning it did not seem to help for very long. I had always wondered that maybe Bubba did not clean the grease off his hands way back when
I have had the the sticky wheel on all my C-3's with that wheel. I have cleaned them with lots of products but the condition always comes back. Only thing I do is reclean them when they get sticky. An answer to this condition would be great.
once they do that the only way to fix it is to replace it. it will keep comming back. i had that problem on my 70. i had to buy a new wheel. be carefull when you buy a used wheel because it might have that same problem. the seller might have just cleaned it off. i think its the plastic going bad. the hand grips on my exercise bike did the same thing, no cure.
I had the same fustrating problem with my 78 non-tilt all rubber four spoke steering wheel. I agree with some of the others that its probably the plasticizers(?) leaking out. I had an aftermarket wheel on the car for a while to make the car useable but when I wanted to have it judged I had to put the original back on. I have an Oyster White interior so the wheel was dis-colored as well.
My solution was to clean the wheel with a rag lightly soaked with either MEK or lacquer thinner (can't remember), then I sprayed it with interior dye. It seems to have worked pretty good for about the last year. I think if I were to redo it I would try some kind of sealer first and the interior dye. I guess if you don't need to dye the wheel you could find some kind of sealer that would not change the appearance of the original finish also.
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
