Warning: Undefined array key 942 in .../vb/library/content.php on line 3508 Warning: Trying to access array offset on value of type null in .../vb/library/content.php on line 3510 Warning: Trying to access array offset on value of type null in .../vb/user.php on line 737 Warning: Undefined array key "online" in .../vb/library/content.php on line 3522 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Undefined array key "birthday_search" in .../vb/api/user.php on line 165 Warning: Undefined array key "joindate" in .../vb/api/user.php on line 182 Warning: Undefined array key "posts" in .../vb/api/user.php on line 183 Warning: Undefined array key "posts" in .../vb/api/user.php on line 189 Warning: Undefined array key "userid" in .../vb/api/user.php on line 6480 Warning: Undefined array key "userid" in .../vb/api/user.php on line 204 Warning: Undefined array key "privacy_options" in .../vb/api/user.php on line 246 Warning: Undefined array key "userid" in .../vb/library/user.php on line 5342 Warning: Undefined array key "userid" in .../vb/library/user.php on line 1594 Warning: Undefined array key "lastactivity" in .../vb/library/user.php on line 1610 C2 power steering control valve - NCRS Discussion Boards
  • Joseph T.
    • March 1, 1986
    • 169
    Anyone tell me who sells the "end cap" for the power steering contol valve. I would prefer one with an X as original but any type cap will do. Thank You in advance.
  • Steve F.
    • Today
    Re: C2 power steering control valve
    Lone Star Caliper
    • Jim S.
      • March 1, 1986
      • 1392
      Joe,
      I was just about to have mine rebuilt by a local shop, when I looked in the box of parts I got from the seller of the car , and I found a newly rebuilt valve by "A1 Cardone" So close to the original that I consider it a done deal !
      It does not have the X in the cap but it is all there !
      My long way around point is this, either your local rebuilder shops may have some lying around or it would seem that Cardone should have them .
      It is probably worth a phone call. Their tech support line # is 888-280-8324
      Jim
      • Chuck S.
        • April 1, 1992
        • 4668
        I'll be interested in responses to your question.
        The last I heard years ago was the "C" marked end cap was available. Since the end caps were mechanically identical, the "X" marked Corvette end cap, however, was not to be found. The "X" must have been a marker or broadcast code to identify Corvette specific valves. Once the vehicle assembly was complete, the actual mark, like other broadcast codes, was irrelevant...yeah, right, except for judging.
        • Joe R.
          • March 1, 2002
          • 1356
          Lone Star Caliper has the "X" caps available from time to time.
