I've checked the archives and only confused myself more. I have a replacement oil pressure line that runs from the back of the block to the oil pressure gauge that I bought from Paragon. It came with the steel line and a fitting for each end. I know enough about household plumbing to expect these to be compression fittings. There was nothing in the kit to slip over the line to compress when tighened down. Only the two fittings that screw into the block and gauge back.
Is this correct? If another piece is required wouldn't you think it would be included in the kit? I can't find anything in any of the catalogs mentioning it. How else would it seal? The fittings are tappered like they should seal against something.
